FYI - Hair can get wrapped around the blade in the SeaEra head and cause the blade to not work properly. The signs of this are flushing that takes longer than usual and worsens over time until waste will no longer empty out of the head bowl.
The voice of experience now says, fix this BEFORE there is solid waste in the bowl and be sure to put the o-ring on the female side when putting the motor/impeller/blade back together.
http://www.raritaneng.com/products/toil ... a_era.html
Beward of Hair in Head
