Winterizing Hot Water Heater
I'm able to keep my boat in the water and use it year round but sometimes the temperatures fall below freezing.
Has anyone figured out a way to keep the hot water heater operational yet protect it and the hoses from freezing?
LONGHAWK
winter-keeping the hot water functional and not freezing
Post by LONGHAWK »
I live in Texas, on Galveston Bay. The water in the bay does not freez, so our conditions are not severe. I use one of the Jack's air dryer devices (essentially an intrinsically safe hot plate). I lay it in the stbd. sugar scoop stern area and leave it plugged in to the 110 v system via an extension cord. It seems to keep all cozy back there.
Sam
LONGHAWK # 173
gkyle
Post by gkyle »
I live in the Northeast (NYC) and have not winterized my hot water as I work on - and 'stayaboard' - my boat. What I did last winter (and this) is put an engine heater in the storage area on the starboard aft side (on the shelf above the water heater). As the heater is non-flammable and is designed to kick on when it gets too cold, that seemed to work well last January and I hope this Jan as well.
Greg Kyle
Irie Life #209
Actually winterizing
Post by R.B. »
Our boat was just pulled out of the water this weekend, and I need to winterize. I have drained all of the tanks, and tried to run the pink antifreeze through the system but after 6 gallons I am still not getting a solid pink flow through the hot water system. The cold side is fine. I did not bypass the hotwater tank as others have done in my marina. My question is: How do I bypass the tank easily. Do I crawl in the aft locker and disconnect the hot and cold hoses from the hot water tank or is there an easier location where I can do this ie. the manifolds in the bilge.
Also how is the hotwater tank loop that goes to the heatexchanger at the engine drained?
Thanks in advance.
jdamann
Hot Water By Pass
Post by jdamann »
I made up a bypass hose that I use at the manifold. Diconnect the cold water feed for the hotwater heater and the hot water return that feeds the hot water manifold. Use the bypass hose to connect directly between the manifolds. I also open the hotwater tank drain and presure relief valve so the tank and the lines all drain free.
As for the engine loop....no need to worry about this...it is the closed side of the system and has engine anti freeze in the line already.
Hope this helps
Happy Sailing
John
"Just Add Wind" 347
