Anyone id the brand of manifold/fitting on my c350
Kingofcary
Post by Kingofcary »
Hi Folks … I have attached a pic of hot and cold manifolds and associated fittings located in my bilge. Would someone know the brand ??? Can’t seem to find. I have a Catalina 350 ‘07 … thanks in advance. Dennis
c350 manifold.jpg (67.5 KiB) Viewed 7400 times
TEM58
Re: Anyone id the brand of manifold/fitting on my c350
Post by TEM58 »
Are you trying to find a replacement? If so, won’t this work- https://www.catalinadirect.com/shop-by- ... e-control/ ? There’s one for hot also. CD may be able to tell you the manufacturer as well.
Tim Meredith
Perfect Match II
2003 #35
Belton, TX
seatime2
Post by seatime2 »
Hi Dennis, I had spares supplied by Sea Tech in 2008 and the manufacturer appears to be https://www.ssicustomplastics.com/
Richard Jenkins
Nancy Scott
C350 439
