Thank you djones. FYI.......... RECEIVED SOME GREAT INFO FROM CATALINA YACHTS: Here's how to drop the rudder:
There are Typically three (two for sure) things that hold the rudder in place or keep it from dropping.
1. The top cross bolt shown in drawing that goe thru the shaft just a few inches down from the top accessible from the cockpit sterring well in floor.
2. The Edson two piece radial wheel that has 4 bolts that clamps it on to the rudder as well as one bolt that goes thru the center of the unit and thru the shaft. (look for about 5 there total until you can hold both pieces of the radial wheel in your hands like a split pizza
(After loosening the steering cables of course)
3. An optional autopliot tiller arm will also have a bolt that goes thru the shaft center.
Once these three are all removed, if you ease off your bottle jack (or boards) the rudder will come down. (rudder wieghs about 150#).
I have a drawing ("Lower Rudder Bearing Refastening" from Catalina Yachts) of the Rudder Bearing Assembly which includes step by step instruction for re-gluing the lower rudder bearing. I plan on re-gluing in the Spring of 2012 when the weather is warm enough for the adhesive to cure. I will be happy to e-mail the drawing if you need it.
richardadlesic@verizon.net
