turnbuckle anti seize?
Posted: Tue Mar 05, 2013 10:06 am
by elk
I was told by the PO, also a pro rigger, that the turnbuckles should be loosened and lubed each season to prevent seizing. Does anyone do this? And if so, what lube is used?
Re: turnbuckle anti seize?
Posted: Tue Mar 05, 2013 2:08 pm
Good idea. Use Lanacote:
http://www.westmarine.com/webapp/wcs/st ... TZCdld5fHo
I don't recommend the use of any petroleum-based product, as it gets on the deck.
Posted: Tue Mar 05, 2013 3:29 pm
by elk
Thanks for the reply Brett. I have some Marelube, which seems like it should work too. Since I'm doing it each season...I'll let you know if it doesn't.
Posted: Tue Mar 05, 2013 4:36 pm
Yes, you have three dissimilar metals in contact in the turnbuckles-- bronze, chrome and stainless steel. Lanacote is just anhydrous lanolin. Been used as a lubricant around boats for at least 2000 years.
I put a piece of tape on the threads where they meet the turnbuckles, both above and below the turnbuckle. That way you can quickly go back to your original tension. I do use a tension gauge before putting in the cotter pins, as SS wire does stretch.
Do them one at a time.
