Rotory Aire Thermostat
Posted: Sun Nov 20, 2011 3:59 pm
by malexander24
On the Westerbeke AC unit with a Rotory Aire digital thermostat, Is there a way to make it stay in Heat only or Cool only?
Mark Alexander
SV "M&M"
Kerr Lake NC
#162
Re: Rotory Aire Thermostat
Posted: Wed Nov 23, 2011 6:10 am
Mark, I don't have a Westerbeke A/C system so I'm only guessing here. You system is basically a heat pump. If you can't run on just heat or A/C, why not call Westerbeke and see if you can use an off-the-shelf thermostat for your system. If so, they should be able to help you with the wiring of the third party thermostat. My Mermaid system will operate with this type of thermostat.
