Dorades
Posted: Sun Jul 15, 2007 5:08 pm
by LONGHAWK
Has anyone installed (or seen a setup that would work) dorades on the 350? The only function that I found that I need that I have not found a good solution for is air movement in hot / inclement weather or offshore in bad weather.
I am asking the all-knowing list for ideas.
LONGHAWK #173
Dorades
Posted: Fri Jul 20, 2007 7:51 am
by Triumph
I have installed two of the solar vents on the two hatches over the main cabin. They are the larger, stainless ones, and I put them in the center of the plexiglas hatches. I have the 4 3/4" hole saw if you decide to go this way.
I figured this was best to suck the hot air out of the boat, and avoid water coming in like might happen if i had put one in the front hatch. They are up high, and not likely to get doused.
Re: Dorades
Posted: Tue Jun 03, 2014 9:52 am
by jonnjones
This is a pretty old thread, but I'd like to repeat the question. Anyone install Dorades or any other ventilation upgrades?
