Engine rpm and speed
Posted: Tue Jun 09, 2026 5:39 pm
Hi,
I have had my 350 for about 2 years now and am beginning to get to to know her.
The engine M35B is still a bit of a mystery to me, is mine a good one? Hard to know without seeing another one in action. I attach a picture as proof that it looks to be in good condition and I keep a close eye on it in the usual way.
I find it a little vibey and noisy but it starts 1st time every time and works, i just think that it should push the boat more quickly through the water.
So my question is around rpm and boat speed.
I know the speed varies depending on lots of factors, sea state, hull clean, prop type size etc.
However recently on a calm day I thought I would try and get some basic performance info. My boat has a featherstream prop, the bottom is pretty clean. I found that my maximum cruising rpm was 2500 to 2600 rpm before I started getting a little high temp chirping from the control panel next to the helm. In addition if I pushed it above that I could start to smell that the engine was getting warm from the cockpit, a coolant sort of smell! As soon as I brought it down to 2500 rpm all was fine again. Anyway the max speed I got through the water was 5.5kts. I find this quite low. How does this compare with other 350 owners is my question??
