fresh water hose replacement
Posted: Sat May 25, 2024 2:00 pm
by Steve A
Does anyone know where I can get a replacement for the hot water hose running from the water heater back to the manifold? Who is the manufacturer? Our boat is an '04. Thanks
Re: fresh water hose replacement
Posted: Sat May 25, 2024 2:15 pm
Steve,
Which hose, the one for engine coolant or potable water??
Posted: Sun May 26, 2024 5:33 am
Catalina Direct has the potable water hose. You could also consider 1/2" Pex but would also need Shark Bite fittings or a crimper so it may just be cheaper to go with the CD reinforced PVC.
Posted: Sun May 26, 2024 8:42 am
by Steve A
Potable water hose.
Posted: Tue Jul 30, 2024 8:44 am
by sjones12121994
You can get a replacement hot water hose for your boat at marine supply stores or online retailers like West Marine or Amazon. Check the hose for any markings to identify the manufacturer, or consult your boat's manual for specific part details. If you're unsure, a local marine mechanic or service centre can also help you find the right replacement.
