Fridge freezer divider bulkhead
Posted: Mon Oct 24, 2022 4:10 am
by D&M
Hi all,
I have an issue with smell in my fridge and freezer. It is self inflicted, in that when we last turned off the freezer we inadvertently left a cryovac-ed expensive steak in the freezer compt. It was jammed between the evap plate and the outer bulkhead of the freezer ie unnoticed. Our system is fairly unique in that we installed a second Danfoss BD50 and evap plate in the fridge section. (I live in the tropics and no amount of insulation was going to provide a working fridge/freezer with a spill over fan.) When we are not travelling, we turn the freezer off as the new BD50 in the fridge runs on shore power as well as 12v.
So back to the problem, when the blood from the aforementioned steak ran into the bottom of the freezer compartment and subsequently into the fridge the smell started. I have now turned off and emptied the fridge as well to deal with the smell. I find the divider bulkhead between the fridge and freezer to be part of the problem as it is not sealed at the bottom and tends to allow nasties from the freezer to the fridge. When I attempted to remove this bulkhead by taking the screws out it seems to be screwed from both sides and some of the screws in the freezer compt are partly concealed by the evap plate which is a pain to remove and reinstall.
Has anyone removed this bulkhead between the fridge and freezer and if so, how did you do it?
Cheers,
Re: Fridge freezer divider bulkhead
Posted: Tue Oct 25, 2022 2:02 pm
David I’ve never removed the bulkhead you’ve referenced but have a “long shot” possibility. I’m a retired veterinarian and frequently had to deal with blood on a white smock. I found that full strength hydrogen peroxide would completely remove the stain. I don’t think you have anything to lose by giving it a try. If you’ve already applied other liquids they may negate some of the peroxide benefits but in a worst case scenario you may end up with a “bleached blond” freezer.
Posted: Sun Nov 06, 2022 3:08 am
by D&M
Hi Kent,
thanks for the reply will try that.
Cheers
Posted: Fri Dec 02, 2022 2:41 am
by D&M
The hydrogen peroxide solution worked very well. The smell is completely gone.
Thanks.
Posted: Fri Dec 02, 2022 5:10 am
Great ! Thanks for the update. So are you saying that was a "bloody good" fix?
Posted: Wed Apr 19, 2023 7:24 pm
by D&M
Sorry Ken didn’t see this reply until now. My notifications don’t seem to work will have to investigate. Bloody oath mate. Great fix. :D
