Condensate drain
Posted: Sun Aug 27, 2017 4:09 pm
by SeaBreeze
My 2003 Catalina 350 has the original Westerbeke Rotaryair AC unit enclosed in a box plenum in the starboard cockpit locker. Does anyone know how the condensate is removed from the boat?
Rick
Re: Condensate drain
Posted: Mon Aug 28, 2017 7:02 am
by leigh weiss
Rick,
On our boat the condensate drain is the second small outlet above the waterline on the starboard side. One drain is the cooling/heating water for the AC.
A hose comes from the bottom of the AC pan and is gravity fed to the drain.
I had to replace both of these through hull fittings as they deteriorated from sun exposure or old age. I chose Polished SS as the replacement.
It was a tight spot to remove and replace. The anchor locker drain through hull fitting also suffered from the same condition and was also replaced.
Have fun crawling in tight spots.
Cheers,
Posted: Thu Aug 31, 2017 9:55 am
by SeaBreeze
I took the AC enclosure apart. My condensate drain is a venturi that sucks condensate into the sea water discharge line as its leaving the condenser.
Rick
Posted: Thu Aug 31, 2017 1:30 pm
by Guinevere
Rick -
If you have a chance, I''d be very interested to see a picture of the venturi setup in your condenser drip pan. I have been thinking about doing the same.
Ours drains into the bilge and we either suck it out at the end of weekend with a shop vac or come back to a smelly boat the next Friday.
Also, do you have a check valve in the suction line from the condensate pan for safety?
Guinevere
#243
Posted: Sat Sep 02, 2017 10:05 am
Mermaid makes a kit for removing condensate via the water pump discharge line.
https://www.mmair.com/marine-division/a ... ndensator/
It has the Venturi device, check valve, filter and needed fittings. I've had one for many years and it works great.
Posted: Thu Sep 07, 2017 12:45 pm
by SeaBreeze
Sorry for the slow response. I was wrong. No venturi. Gravity drain.
Rick
