Raw water impeller replacement interval / pump retrofit
dedgell
Post by dedgell »
Yesterday I changed the impeller in my Sherwood water pump. I was reminded again of what a terrible design that is. I don't change the impeller often enough as I dislike that job. The impeller had last been changed 200 hours and three+ years ago. The old impeller looked fine upon removal, but I must admit that the engine pumped better with the new one in place.
Two questions:
1. What is the appropriate replacement interval for the impeller, i.e. How often should it be changed?
2. Has anyone upgraded to the Oberdorfer pump retrofit available from Catalina Direct? http://www.catalinadirect.com/index.cfm ... ngines.cfm
If so, please let me know of your experience. I'm thinking that next time I may just upgrade the pump since it appears the impeller is much more accessible.
Thank you for your thoughts
David Edgell
S/v Blue Wing
C350 #442
wcconway
Re: Raw water impeller replacement interval / pump retrofit
Post by wcconway »
Our mechanic upgraded to the Oberdorfer. It's has worked great. No issues. I have pics, but it won't let me upload from my iPad. If you would like pics let me know and I can email.
This was discussed recently on the C34 message board and also has a link to the C36 board - http://c34.org/bbs/index.php/topic,9410.0.html
C350ia
Post by C350ia »
Th eOberdorfer M202N 908 is the best way to go. Oferdorfer redesigned the unit just for the M35B and is works like a charm with removing and replacing the impeller from the front, just 4 screws and a snap ring pliers. Try this link for a discount.
Mike Cronin
#314 FlagShip
Mike I think the Orberdorfer part number you want is N202M-15. (M & N were transposed in your original post).
C350ia
Post by C350ia »
Yes Ken, I got the M and N reversed. I checked my invoice and I ordered the N202M-908. In conversation with Oferdorfer, if you want to get brass "L-brackets" or hold downs, order N202M-837 which is both the pump and L-brackets.
dedgell
Post by dedgell »
Thank you all for your comments and advice. I'll probably go ahead and change the pump out next year as I'm commissioning, or before if the Sherwood starts leaking.
David Edgell
S/v Blue Wing
C350 #442
Chuck_on_Hudson
Post by Chuck_on_Hudson »
Question about this Oberdorfer pump...is it 100% compatible with the M35 engine, or does the base of the pump need to be modified as described on the Catalina Direct website and the C34 forum?
http://www.c34.org/wiki/index.php?title ... Oberdorfer
A few years ago, I believe that if you bought the Oberdorfer pump, you have to machine away part of the base so it would fit on the engine block correctly because that pump was not specifically made for the Catalina 350 engine. Has Oberdorfer created a new model with the base 100% compatible with the OEM Sherwood?
Chuck
C350ia
Post by C350ia »
The Oferdorfer N202M-908 is the model redesigned by Oferdorfer as a direct replacement for the Sherwood. Good Luck
zman18
Post by zman18 »
Can I just confirm that the Oferdorfer N202M-908 can be used on the M35B with out any modifications? If so any suggested sources for purchase.
John
Hull # 484
John Zoda
Compass Rose
Hull# 484
JohnNorton
Post by JohnNorton »
Sounds like you have something on your prop/prop shaft hitting the hull. I'd dive in and take a look.
