Battery Hydrogen Gas Generation
Posted: Tue Feb 28, 2017 9:38 am
by Interlude35
We have been considering adding a vent to the battery compartment as the batteries generate some hydrogen gas when charging. Hydrogen gas above 4 percent concentration is considered an explosive mixture. I have not heard of any problems due to hydrogen generation and a literature search indicates hydrogen gas is very light and will escape through a very small opening dissipating very quickly. I am not sure any action is needed and would appreciate any thoughts on this topic.
John & Marilyn Ferguson
Interlude 316
New London, CT
Re: Battery Hydrogen Gas Generation
Posted: Wed Mar 01, 2017 12:08 pm
Many of us have gone with AGM batteries because they do NOT out-gas unless severely overcharged.
Was introduced to them (Lifeline brand) in the mid 1990's because they came as standard equipment on our Pacific Seacraft Crealock 37'.
Posted: Sun Mar 05, 2017 11:35 am
by Interlude35
Thanks Brett- were you required to change the alternator? Have you done any other changes to accommodate the AGM batteries? How have they lasted? Thank you
John Ferguson
Inderlude 316
Posted: Sun Mar 05, 2017 2:09 pm
Interlude35 wrote:Thanks Brett- were you required to change the alternator? Have you done any other changes to accommodate the AGM batteries? How have they lasted? Thank you
John Ferguson
Inderlude 316
John,
No, changing to AGM's does not require changing the alternator.
BUT, all battery technologies will benefit from a higher output alternator and smart regulator. Have done both and run sense wire for the regulator to the battery #1 so the batteries see absolutely the recommended charge voltage.
The higher output alternator speeds charging when at anchor and using the engine for charging.
The smart regulator speeds charging when at anchor and using the engine for charging AND also keeps from over-charging the batteries when motoring all day (goes into float mode).
