fresh water hose replacement
Steve A
Post by Steve A »
Does anyone know where I can get a replacement for the hot water hose running from the water heater back to the manifold? Who is the manufacturer? Our boat is an '04. Thanks
Steve Abdow
S/V Jester, Hull 160
S. Dartmouth, MA
Re: fresh water hose replacement
Steve,
Which hose, the one for engine coolant or potable water??
Catalina Direct has the potable water hose. You could also consider 1/2" Pex but would also need Shark Bite fittings or a crimper so it may just be cheaper to go with the CD reinforced PVC.
Steve A
Post by Steve A »
Potable water hose.
Steve Abdow
S. Dartmouth, MA
sjones12121994
Post by sjones12121994 »
You can get a replacement hot water hose for your boat at marine supply stores or online retailers like West Marine or Amazon. Check the hose for any markings to identify the manufacturer, or consult your boat's manual for specific part details. If you're unsure, a local marine mechanic or service centre can also help you find the right replacement.
