Servicing Harken 42 Winches
LI_Sound_Cat
Dan
“Glandore”
#161
“Glandore”
#161
Re: Servicing Harken 42 Winches
Dan, I did the same service on my winches last fall. I can’t imagine new grease causing the problem you’re describing. Do you hear the pawls clicking when you turn the drum? I managed to put one set in backwards on mine. One option would be to start disassembling another winch and carefully take pictures at each stage. Then check the winch that’s problematic and see if a part has been reinstalled incorrectly.
From Harkens web site:
When reassembling Harken Classic winches, make sure the ratchet gears are the correct way up, with the pawls sitting properly in the teeth. Failure to ensure this may cause excessive wear or friction in the winch.
As a last resort, give Harken a call and see if there’s anything else that might be causing your problem.
LI_Sound_Cat
Thanks very much Ken — I will try that on the second winch and that is a good idea. How did you know that you put the pawls in upside down? I had read about that issue as well but when reassembling couldn’t see how it could go in that way.
Dan
“Glandore”
#161
“Glandore”
#161
Oh, the pawls CAN be installed "backwards"-- the "round part" will still fit in the "socket". And, it will cause the symptoms you have. Remove the drum and check. Post a picture if you have a question.LI_Sound_Cat wrote: Tue May 21, 2024 1:53 pm Thanks very much Ken — I will try that on the second winch and that is a good idea. How did you know that you put the pawls in upside down? I had read about that issue as well but when reassembling couldn’t see how it could go in that way.
You’re asking me to remember something from 6 months ago ?
. As I recall the winch wasn’t operating properly and I wasn’t 100% sure I had the pawls oriented properly. There is a very subtle difference in how the pawls look when properly installed.
Prior to starting this project I couldn’t find a winch manual and called Harken. They were helpful and easy to get a hold of.
LI_Sound_Cat
Brett and Ken — can’t thank you enough. Sure enough I had it backwards…spinning free and clear now. Much appreciated.
Dan
“Glandore”
#161
“Glandore”
#161
Dan - Thanks for "closing the loop". Posting solutions can be very helpful for the next person searching the forum with the same problem.
