Brown caulk in saloon?
Guinevere
Post by Guinevere »
I have just finished cutting and "releasing" the section of the saloon veneer which is problematic on our boats.
Ready to use contact cement to re-attach but will need to caulk a bit at the ceiling and sole.
Has anybody found a match (or close match) for the brown caulk used by Catalina?
Also, has anybody tried to find the white/cream flexible tubing (above the shelf above the head, for example) as I thought that might work as well (especially at the ceiling).
Guinevere
#243
Re: Brown caulk in saloon?
Post by Triumph »
I used black caulk. I taped off both sides of the crack and made it neat. It looks factory.
Bill Triumph
