Looking to buy a 350
malexander24
Post by malexander24 »
Just put out Catalina 30 up for sale and are on the hunt for a 2003 to 2005 model. Are there any critical issues that I need to be aware of when checking out a 350?
Mark
Kerr Lake, NC
Mark Alexander
SV M & M
Kerr Lake NC
#162
Re: Looking to buy a 350
Hello Mark and welcome to the C350 web site.
Aside from having any prospective boat checked by a competent surveyor, here's a couple of things that come to mind. I'm sure others will add things I've overlooked.
Fuel filter bracket service bulletin - http://www.westerbeke.com/mdtools/servi ... sb_247.pdf
Anti-siphon kit upgrade from Catalina - http://www.catalina350.net/phpBB3/viewt ... ?f=11&t=52
Steaming light problem - http://www.catalina350.net/phpBB3/viewt ... ?f=10&t=90
Prop cavitation issue - http://www.catalina350.net/phpBB3/viewt ... f=13&t=138
malexander24
Thanks, that is exactly the type of info I was looking for. We will be scoping out 3 Cat350 this weekend.
Mark
Mark Alexander
SV M & M
Kerr Lake NC
#162
malexander24
We saw 3 Catalina 350 this weekend in Virginia. Two of them had the veneer delimitating of the wall. One had the spreader light missing parts and one I could see had the old filter bracket. 2 of them have potential. There are 3 more in Florida that we may take a peek at too.
Mark Alexander
SV M & M
Kerr Lake NC
#162
malexander24
Had the survey on a 2004 on Friday. All looked good except for two issue.
Head would refill after flushing and cutlass bearing had some play with only 108 hours on the engine.
Should be taking possession at the end of March.
We are very excited for our next, and probably not last, boat.
Mark
Kerr Lake NC
Mark Alexander
SV M & M
Kerr Lake NC
#162
Mark,
Congratulations on the new boat. I'm sure you'll enjoy it. If you've read the forum, you probably have figured out that your commode needs a new joker valve.
Good luck and enjoy.
