Engine Instrument Panel Gasket
Posted: Wed Aug 20, 2014 8:46 pm
by ps23435
Greetings. I need to troubleshoot some gauge issues on my engine instrument panel. As one would expect, after removing the 6 screws the panel will not come off without prying it free from the gasket between it and the pedestal. This will surely destroy the old gasket so I am refraining from removing the panel until I have a new gasket in hand. Any suggestions on where to obtain this gasket? I checked Catalina Direct but while they seem to sell the entire panel, did not find the gasket. Thanks.
Pete S.
Slip Away #437
Hampton, VA
Re: Engine Instrument Panel Gasket
Posted: Thu Aug 21, 2014 5:59 am
Pete, if you're in a hurry why not get some Permatex and make your own gasket. Otherwise I'd suggest calling Catalina Parts at 727-544-6681.
Posted: Thu Aug 21, 2014 8:47 am
by jrohrbaugh
I used some kitchen shelf liner material I found at Target. Worked fine. Just measured and trimmed. Cheap too.
I also have had the ghost attacks on my volt meter recently so I've been able to repeat this process a couple of times.
Good luck.
Jamie
Sail #444
Soixante
Posted: Thu Aug 21, 2014 2:20 pm
by Pgtjs
Hi there,
I replaced the gasket using the narrow insulation tape which is sticky on one side. It is a soft rubber strip on the other side which is compressed when it is screwed down. Be careful not to overtighten as one corner cracked and I had to seal it back together using crazy glue. A bigger problem was that the guages leaked in moisture through the bezel galss when it was raining. This I solved by having a clear plastic cover shield made by the sail maker and which has press studs to keep it is place. Works just fine now.
Cheers, Geoff. (Taeko 1V, Semiahmoo, Blaine, WA C 350, # 392. )
Posted: Fri Aug 22, 2014 9:07 am
by nybor
ditto on the sticky sided spongy gap material. I have removed my panel over 40 times (don't ask), so I consider myself a pro. Also, I placed a rubber washer on the screws, since you are correct, it is VERY easy to crack the plastic.
