Start Battery
Start Battery
Any suggestions on size of start battery , cranking amps vs amp hrs. Thanks Joel
That is a great diagram thanks.
Where did you install the starting battery? What is the duo-charge? What size of wire did you use?
I have not had my 350 delivered yet. I thought about having the dealer install this during commisioning but $800 Cdn was too steep for something I could definitely do myself and most likely for alot cheaper.
