Engine Raw Water Strainer
Posted: Tue Sep 10, 2013 6:25 pm
Has anyone relocated the raw water strainer for the engine? Ours is located near the PSI shaft seal under the aft berth cushions and you have to remove nearly everything from the aft cabin to access the strainer. We refer to the aft cabin as the 'aft garage' so clearing out the 'garage' to get to the strainer is a task.
I'm considering relocating it to a location that I can get to more easily, but haven't found any place that looks satisfactory.
Thanks for any suggestions that you have.
