Another starter battery question
Posted: Thu Jun 27, 2013 5:11 pm
I know that this has been discussed in some detail but I cant seem to figure out what is the best way to wire / connect a separate starting and house battery configuration. Unfortunately, my understanding of this kind of thing is almost at the "don't stick your finger" in an outlet level. I have read all of the posts, printed numerous wiring diagrams that folks were very kind to post, scoured Calder and I am still stumped. I want a fool proof system (I'm the fool) with both circuits separate so that I don't have to touch the switches except in an emergency.
I have Hull number 383.
I have installed a starting battery and an Echo charge unit. So far so good. Where I run into trouble is the BIG question (for me) of how to arrange all the wires and switches I have. I think I have the Echo charge unit installed and wired properly and the black ground from the New Start Battery to the Black ground for my 4D's.
My question is where to connect the Red wires so that the alternator will charge the house bank and the Echo charge will charge the Start Battery?
My first attempt was to take off the short red wire connecting the Common post on the 1,2,Both, Off switch to the Engine Off /On switch. I then connected the Start Battery Red to the Engine On / Off switch. This proved to be incorrect as I drained my house bank down to Alarms sounds (the worlds going to end) level during a long day of sailing and motor-sailing in unfamiliar waters. I figured out (with the help of a FRIEND) that my wiring arrangement wasn't sending the alternator output to the house bank at all. The motor started great, all the other electronics, not so much. Alternator output was OK, checked with a multi-meter.
At this point I am considering running a cable (what size?) from the alternator output to the Common on the 1,2,Both, Off switch. I am concerned though that I will probably blow something up by doing so.
Please help. I can follow Step by Step instructions; "See Jane Run" type instructions. Thanks in advance
Dave on Ventosa on Vandemere Creek, Off the Bay River, off the Pamlico Sound, North Carolina.
