Can you Identify this?
Posted: Mon Mar 26, 2012 7:59 pm
Hello again.
take a look at the attached photo.
Am I correct that the hole in the side of the - not sure what to call it, its not a strut - hull just forward of where the shaft exits is a water inlet to cool the cutlass bearing and PSS shaft seal?
What about the 4 additional holes. Should there be a grate or filter over the hole to prevent "stuff" from getting in there.
Thanks again and again and again. The group has been incredibly helpful since I got the boat.
