HELP! Our fill cap for the fill hose for deisel was deep-sixed by an idiot fuel-dock employee. I rushed out to my local west-marine and bought a "standard" fill cap to replace it but it didn't fit (it was too big)! Now I don't know what size the 350 (original mark-I, 2003) is using and where to get one since West Marine didn't offer any other sizes. I tried searching online but didn't find any that were smaller than the 1.5" size that I already tried. Anyone know what size I need and where to get one? I'm in a hurry because it's raining and I don't want to get water in the tank. Currently have duct-tape over the fill, but not sure how long that will last...
(also, not sure if this should be under plumbing or engine, so will post in both locations...)
Replacement Fill Cap for Diesel?
Phil
Paramethia
Hull #55
Paramethia
Hull #55
Re: Replacement Fill Cap for Diesel?
Here you go - http://www.catalinadirect.com/index.cfm ... ct_ID=1256
I had the same thing happen. Use the cap from the forward water fill in the anchor locker for the diesel fill cap - they are identical. I used a wooden thru-hull plug for the water fill until I could replace it - its under the anchor locker lid anyway so it is out of the elements. I did get the replacement at West Marine - there are different sizes. Good luck!
