Ken,
Thanks for your reply. I received a message from the Schaeffer service group about the head sail furler here it is:
Dear Mr. Grasman,
Thank you for contacting Mauri Pro Sailing.
There are many potential causes to this problem you are experiencing, but I will
list the most common checkpoints:
-) Drop the Genoa or Jib and try to furl/unfurl the unit. See if the problem is
still there.
-) Make sure you have good headstay tension. Too much sag on the headstay will
increase the friction along the foils over the wire.
-) Try to see or hear if there is something unusual in the drum bearings.
-) Rinse the unit with fresh water and apply some dry lubricant such as McLube.
-) Check the top swivel bearings and make sure is running freely.
Those are the typical simple points to check. If the furler is still hard to
turn without the sail on, then try to identify if it is due to the drum or the
foils. What I mean by the foils is that the foils section connectors roll over
the actual headstay and sometimes dirt or one of the strands of the wire gone
out of place or broken is causing the whole problem. This is a harder task since
disassembly of the foil is required, so I wouldn't go that way before checking
the above.
Hope this helps.
Sincerely,
Rod Favela
Mauri Pro Sailing
Your direct access to sailing solutions.
Mauri Pro Sailing <
http://www.mauriprosailing.com/>
Toll Free: 1-888-756-8883
International Calls: +1-817-224-2209
P Please consider our environment before printing
----- Original Message -----
hagra@aol.com>
To: "Juan" <
support@mauriprosailing.com>
Sent: Saturday, May 30, 2009 4:37 PM
Subject: When you were offline (via LivePerson)
> [To:] Tech Info
> Need info on Schaefer rolling system 2100. Very hard to furl and unfurl.
> Please advise what action I need to take to solve this problem.
> Have not applied any thing to drum other than water pressure to clean out
> salt.
> Thank you
> Hans Grasman
Ken and all,
I am going to address this issue after Nov. 1 when I get back to Florida.
In August I have the second installment of "Boat Swap" . I will be in Kingston Ontario sailing David White's C350 for 2 weeks.Looking forward to that.
Hans
