garhauer ez glide genoa cars
Posted: Fri Oct 03, 2008 9:42 pm
by william vanwagoner
I just purchased a set of garhauer ez glide genoa cars with the optional cam cleat, and was wondering if anyone else has installed these on a 350. Specifically, I would like to know what size line and length you used. In addition, I saw a post for a larger Catalina which included a bungee between the car and the cam cleat. Is this necessary, and if so, what size and length did you use? I would welcome any suggestions.
Bill VanWagoner #229
Re: garhauer ez glide genoa cars
Posted: Mon Oct 06, 2008 10:43 am
by jdamann
I have also installed these on my boat. Best upgrade I have done and well worth the money. I used 5/16 line, same as the jib furling line. I do not have a bungee cord on mine, not necessary.
Enjoy
John
Posted: Tue Oct 07, 2008 11:59 am
by tjr350
Bill,
The installation of the garhauer ez glide genoa cars would make a great article for the Mainsheet Tech section. Would you mind taking a few digital pictures as you go about the process? Just write up a brief description of the project and send it to me via e-mail, along with any pictures, and I will get it into Mainsheet. Many owners would love to see and read about this upgrade.
Thanks.
Tim
C350 #332
tjr3c@comcast.net
Posted: Tue Oct 21, 2008 8:49 pm
by wcconway
We want to install these in the spring, so we would appreicate any suggestions and installation tips you can provide. And, pics would be great, too!
Posted: Sun Feb 15, 2009 2:56 pm
by Bob Hart
Bill,
Thanks for your technical article in the Feb 2009 Mainsheet. I would like to do this upgrade on my 'Espresso'. Questions: The Garhauer website shows 1" and 1-1/4" sizes and standard or heavy duty models. They also indicate that I need to supply the thickness of the Genoa track top T section. Since my boat is in storage and an hour away, I don't have easy access to the track dimensions. Which model should I order and what is the T-track dimension they need?
Also, should I order direct from Garhauer or are there distributors, like Defender, etc.?
Posted: Tue Feb 17, 2009 12:15 am
Bob,
I purchased the middle model E-Z Glide system (I think it is the G-2UB) with the optional swivel cam cleats, which are for a 1- 1/4" track and fit the standard C350 genoa track without modification. I assume the C350MkII has the same track as the MkI. I bought my set at Garhauer's booth at the Long Beach Boat Show last year from a gentleman named Mark, and he indicated that the heavy duty model is for boats much larger than ours. I would purchase directly from Garhauer as they know our boats well, and know just what we need. Mark sails a Catalina 36, and his father, one of Garhauer's founders, owns C350 hull number 1.
Good luck,
Posted: Tue Feb 17, 2009 12:28 am
by Bob Hart
Bill,
Thanks for the info. They are on order.
Posted: Wed Feb 18, 2009 4:16 pm
by wcconway
sent a note to garhauer....here is their response. We plan to order and install in April.
-----Original Message-----
garhauer@garhauermarine.com [mailto:
garhauer@garhauermarine.com]
Sent: Wednesday, February 18, 2009 2:28 PM
To: Conway, Connie
Subject: Re: [webform] Garhauer Contact Form
This is the correct item. You must specify that it is for a C-350
----- Original Message -----
ceconway@southernco.com>
To: <
info@garhauermarine.com>
Cc: <
audit@interservent.com>
Sent: Tuesday, February 17, 2009 9:18 AM
Subject: [webform] Garhauer Contact Form
> We have a 2008 Catalina 350. We want to install the adjustable genoa
> cars. We want to make sure we are ordering the corret items. Can you
> confirm we need E-Z G-2UB and SJ-1-1/4?
