Mattress Extensions
Posted: Thu Nov 10, 2005 9:16 am
by jdamann
While at the boat show last month I looked at the new 350. They had optional mattress extensions on the forward berth. Was wondering if anyone had them....could comment on them. Also, how did you handle a bottom sheet for them.
Front Cabin Matress Extensions
Posted: Sat Aug 19, 2006 11:29 pm
by Pgtjs
I believe Catalina calls them "bolsters". We ordered them and they seem well fitted. The Sheets matched the bottom centre sheet and came with the boat when commissioned. Geoff. C350 -392 (Taeko 1V)
Re: Mattress Extensions
Posted: Thu Aug 28, 2008 1:07 am
by tranquilcat42
I ordered them late last season and still have not found anyone to install them. Two of the six peices they sent are very long and not sure where they would be placed.
Geoff - how did you install them? They look like a great addition
Teri - Tranquilcat 42
Posted: Thu Jun 25, 2009 10:08 pm
by vegasandre
HI I ordered these mattress extensions also and they fit , however they do not have end support so if you put weight on it - it collapses.
kind of defeats the purpose . Going to have to make some kind of brace so it can support the weight
Posted: Thu Jul 16, 2009 6:25 pm
by Terry Ryan
I installed them a couple of years ago and they were great for adding add'l room to an already large V-berth. However, they came with no instructions. They also came with several pieces of teak of varying lengths...think they were 2x2 size. I installed them where they provided the most support and made the bolsters level with the mattress. If you get in a jam, shoot me a reply and I'll send you a photo.
Posted: Fri Aug 13, 2010 7:54 am
by tranquil
OK - can you believe I finally got them installed? Not exactly even with the mattress - I had a hard time getting the drill in to make holes in such a small space.
Now all the queen size fitted bottom sheets I have no longer fit! But I really like them and can pile quite a few of my neices and nephews when they stay over!
Teri
Posted: Fri Aug 13, 2010 5:23 pm
by PHerzfeld
Can you post some pictures of where / how you mounted the supports, when you have a chance? I have had the bolsters for 6 months and haven't figured out which teak piece should be used where...
Posted: Sat Aug 14, 2010 8:34 am
by tranquil
Hope these help I have 6 pictures so if feel comfortable providing an email address, I can send all of them
Catalina did not bore holes in all the wood they sent, so I had to get a special bit and drill myself
These pictures are from a Catalina dealer or FL I think when I installed them I switched them around There are 2 styles, so if they dont fit you might want to contact FL to ask
Posted: Mon Apr 01, 2013 3:24 pm
by belladonna
I know that this is an old topic but I just bought hull # 368 and was curious about these mattress extensions. I don't have them but think they may be useful to extend the width of the aft end of the mattress in the forward cabin. Those of you that have them, would you recommend getting them and if so, where would you suggest that I look to buy since the 350 is no longer in production. Thanx. Jim Lassiter
BELLA DONNA Hull # 368 Deltaville, VA
