Generator Selection
Tdrothrock
Generator Selection
Post by Tdrothrock »
We would like to install a generator to enable us to operate our air conditioner and charge batteries. Many of the posts regarding generators are dated. We are looking for the newest recommendations for a new generator that is quiet, reliable, easy to maintain, fits in the aft port locker area and provides sufficient power to operate the boat’s ac, 30 amp charger, hot water heater. Also, tips on installation and expense are appreciated.
SkuffedKeel
Re: Generator Selection
Post by SkuffedKeel »
Following. I'm interested in doing this as well. If you learn anything elsewhere could you please post here?
"Senja"
C350 # 137
Nanaimo, BC
Tdrothrock
I was hoping for some replies but nothing yet. I just added the dometic smart start 3 to our AC. I am using two Honda EU2000i generators with parallel connections. I might be able to use ac with one generator now. Testing today.
Post by nybor »
I used two Yamahas like you to run the ac. I got it started and I THINK you can disconnect one and it will keep running. It has been awhile since I tried it but am pretty sure it worked.
