cker) and stern (transom) so to be practical I had to put the second 30 amp access at both bow and stern. Great, another $75 for the receptacle and another $95 for a second breaker within 3' of each one.
Now for the question:
I have to run a 12/2 w ground to the lazarette for the power supply and the water supply from the bilge area to the lazarette. I also want to run another 12/2 or 12/3 w grounds to the galley area to put some of the load {micro, coffee maker, toaster, ice maker} to the second power supply.
I can't find a good path from behind the AC panels on the port side over to the starboard side, preferably inside the lazarette.
HELP HELP HELP
Steve
HELP HELP ROUTING WIRE AND A/C COOLING LINE
