Mast up standing rigging replacement
Posted: Mon Dec 19, 2022 11:53 am
Apologies for what might be a very obvious question. I'm currently thinking about how I might replace the 20 year old standing rigging on hull number 55. One of the options is to replace the rigging with the mast up and based on some preliminary reading it doesn't sound like it would be too hard. I could look at pulling the mast if needed but I'd like to work through all the options.
One documented limitation that has confused me is the following:
Any thoughts on the above would be very much appreciated.
Alex
from https://jimmygreen.com/content/162-repl ... step-guide. Is this simply because you won't be able to send the rigging off for duplication and therefore need to be able to make changes in place? I was hoping that the specifications on page 25 of the C350 user guide would allow me to order a complete set of rigging with all terminals professionally swaged. These could then be swapped out one by one with appropriate support from a halyard.If the mast has to remain stepped, you need a slightly different approach, generally involving the purchase of each wire over-long with the top terminal swaged.
The bottom end will need to be finished in situ, by cutting to the exact length and fitting a DIY self-fit swageless (mechanical) terminal.
Alex
