Exhaust Hose loop
Posted: Tue Apr 12, 2022 5:36 am
by Monty
I removed the old exhaust hose (muffler to thru hull) last winter as it was cracked and had potential to leak. In preparing to replace it this spring I can't locate my measurements as to how high, over the thru hull, the loop is. The loop, I believe, is to prevent seawater from backing up the exhaust hose when heeled over and the thru hull is underwater.
I would appreciate anyone that could provide me guidance as to how high the loop should be. Measurements or pictures would be very helpful. Thanks for your help.
"Salty"
Hull 418
Re: Exhaust Hose loop
Posted: Sat Apr 16, 2022 8:21 am
by modesid
Steve
Catalina’s Drawing 53001-4 Engine Exhaust System Retrofit Kit… dated 04/12/04 revised 11/23/05 shows loop to be 35” from top of hose at muffler to bottom of loop… and that the Muffler Modification per Catalina… drawing dated 11/14/05 be installed to level muffler and install Drain Screw
Don Modesitt
Wind Dancer
0011
Posted: Sun Apr 17, 2022 11:03 am
by Monty
Many thanks! Great detail with supporting info. Steve
Posted: Sun Apr 17, 2022 8:35 pm
by Monty
Don; where can I get the Catalina drawing you referenced? Steve
Posted: Mon Apr 18, 2022 5:26 pm
by modesid
Steve
The drawings came with the kit to level the muffler…
You should be able to contact Catalina for that change…
Catalina supplied a chair to place under muffler with instructions.
Cheers
Posted: Tue Apr 19, 2022 6:15 am
by Monty
thanks, I didn't have to change the muffler, only exhaust hose. Steve
