Mystery Leak
Posted: Tue Jan 18, 2022 2:19 pm
by jrohrbaugh
I have an oil leak that is coming from the area of the fuel filter (engine) bracket. For the life of me I can't figure it out.
I seems to be getting worse over time. Any ideas? I have attached a pic that shows the drip.
Thanks in advance for any help
Jamie
S/V Soixante Hull #444
Re: Mystery Leak
Posted: Wed Jan 19, 2022 7:17 am
by D&M
As someone who has replaced that bracket after it fractured, I think the leak is from somewhere higher up the engine block. Have you examined all sources above that point?
Re: Mystery Leak
Posted: Sat Jan 22, 2022 10:26 am
by jrohrbaugh
I am calling my mechanic to look at it. Still can't locate. I've also sent a message to Westerbeke to see if they have any ideas. Lots of chatter about the broken fuel bracket. I don't know if there is to be gasket material on the upper bolt. Maybe that is where it's coming from.
As to the water. I've noticed that my engine connections that are on the sea water side have all turned green. I was in salty/baricle water for a few months. Maybe that is the cause? I also have had an electrical problem wtih the new GFI plug ins. I had a electrical repair guy "fix" the problem by eliminating a shorted out water heater.
Who the heck konw.
Thanks for any reply and ideas you might have. I'll post results of mechancs inspection.
