2 small thru hulls on Starboard side of hull
starfish
Post by starfish »
Hello all,
Can anyone tell me where to access the onboard side of the 2 small thru hulls on the starboard side rear quarter? Mine need to be replaced. Also, are they both 3/4 inch?
Ed
Ed Kleinstuber
s/v Starfish
C350 #333
Re: 2 small thru hulls on Starboard side of hull
I have replaced the two 3/4" drains from inside the bottom of the starboard cockpit locker ( tight fit) and some what hard to swing a tool to take them out. The replacements are SS and wont suffer the sun degradation that the originals had. Found the SS fittings on Ebay. I also replaced the anchor well drain with a SS unit as well. Clean out the locker and have fun squirming!!!! Having smaller and younger friends is a big help.
Good luck.
starfish
Post by starfish »
Thanks very much, Leigh. Can you tell me how long they are? Would like to get them ordered before fighting the removal battle.
Ed
Ed Kleinstuber
s/v Starfish
C350 #333
As I recall, the hull and backing block was about 1" thick plus allow for the threads of the fitting your are looking at about 2" . I don't recall if I trimmed the length to install. The 1-1/2" anchor well drain, once removed gave the dimensions. You have more room for the install in the front.
Have fun.
