Icebox drain pipe and water in floorboards
Posted: Tue Jul 13, 2021 11:01 pm
I wonder if there is any way to inspect the drain pipe beneath the refrigerator that connects to the footpump. I am curious to figure out if the fitting at the bottom of the refrigerator is somehow cracked and maybe water is leaking out before it reaches the footpump. I ask since I am finding a lot of water seeping under my wood vaneer floorboards (and above the "skin" that they are screwed into. I am calling this "between layer" water since it is not in the bilge. When I walk across the floor near the fridge, water gushes and squirts up from the edges of the floor. In the past, I have seen melted ice water spill out of the fridge door ontop of the floor and find its way into this "between layer". But I was careful to not let that happen this season and yet I still have this "between" layer water. Has anyone else had this problem and how did you address it?
