Vertical or Horizontal Evaporator
Posted: Thu May 16, 2019 2:55 pm
I have seen the evaporators installed vertically or horizontally on different 350's. Ours happens to be installed horizontally. It seems to me that the vertical installation would make it easier to access the stored food since it is a top loading freezer. My question is which do you have and do you like or dislike it from a storage and access aspect? Secondly, has anyone attempted to change a horizontal installation to a vertical installation? It appears to be simply mounted to the compartment wall with 4 screws and could easily be rotated 90 degrees and reinstalled by drilling a couple of new holes without disconnecting any Freon lines. Maybe some gentle bending of the evaporator could make it fit the compartment a little better, but it doesn't appear to be a huge job. The downside is you would need 'vertical' ice cube trays if you wanted to freeze your own cubes.
Thanks for any inputs.
