Bilge Cover Deck Fitting in Salon sole
SubVet
Post by SubVet »
The brown frame for the main bilge cover is cracking and I'm trying to determine how to best repair it. Seems that Catalina put a pretty big cover on a relatively flimsy frame and it cantilevers this fiberglass frame. I'm thinking I may need to re-glass it and was also thinking about putting some shims on the keel frames to provide additional support. Suggestions?
Re: Bilge Cover Deck Fitting in Salon sole
Have you checked with Catalina to see if a replacement is available?
With the very few we have seen reported broken, I would not be afraid to go back with the OE design if available.
SubVet
Post by SubVet »
Can't tell without an inspection mirror but it appears that this is just a part of the mold for the sole frame...
