Shaft play - NOT at the cutlass bearing
BillBerner
Contact:
Post by BillBerner »
Springs coming - time t start anticipating bloody knuckles!
How much prop shaft play do others have at the transmission side. Uncoupled, that is.
I've no play at all at the cutlass bearing, but quite a bit where the shaft entered the stern tube in the boat.
Associated question - my pss seal is not water cooled, nor my hurts transmission for that matter. Should either or both of those things be spring projects?
Bill Berner
2003 #66
Stamford, CT
