Companion Way Steps Touch Up
Posted: Mon Oct 17, 2016 8:28 pm
I am usually pretty diligent about touching up my companionway steps to repair the wear they receive. This year I got behind and as luck would have it, I had some rain fall on them and discovered there were some thin spots in my varnish which led to water spotting. After the boat was pulled, I removed the wood and sanded out the thin spots and went about recoating with a water based varnish (as applied new) which I have used for then last several years to over coat. The sanded wood appeared a little dark so I bleached it and let it dry. When I applied the varnish is was easily 2-3 shades darker the unsanded areas. I had heard this could be that the wood was wet - so I scraped the varnish off and dried the wood a few times with a heat gun. Tonight I reapplied the varnish - again 2-3 shades darker then the original finish.
Has anyone experienced this problem ? Any suggestions?
Vineyardsailor
Aurora Blue
Hull 265
Vineyardsailor
Aurora Blue
Hull 265
