Leak with unknown origin
Posted: Tue Apr 26, 2016 7:48 pm
This leak is on the port side about halfway between the port light and the nav station. It starts up near the hull/deck joint. It is not near a stantion location. I noticed a small stain last fall but it worsened over the winter.
As you can see in the pics it appears to originate near a bolt which I assume is for the joint. I will try to flood with hose to check source. I'm not looking forward to removing rub rail to get to joint.
Anyone been here?
Anyone been here?
