Hull number ??
Cmp1110
Hull number ??
Post by Cmp1110 »
Is the hull number the last three digits of the hin??
Re: Hull number ??
Post by R.B. »
I am going from memory here, but I believe so.
Cmp1110
Re: Hull number ??
Post by Cmp1110 »
Fantastic, thank you
Guinevere
Re: Hull number ??
Post by Guinevere »
The hull number is the first set of digits of the HIN--not the last.
Our HIN is CTYV0243_ _ _ _ _ .
The hull number is 0243 (or 243)--the first digits following CTYV.
Guinevere
#243
Guinevere
#243
Cmp1110
Re: Hull number ??
Post by Cmp1110 »
That makes more sense thanks
Guinevere
Re: Hull number ??
Post by Guinevere »
The hull number is also on the Catalina builder's plate under the companion way opening on the cockpit side on ours.
Guinevere
#243
Fritzcw3
Re: Hull number ??
Post by Fritzcw3 »
I was told it was also the number on your sail...
C. Fritz
Nautical Charm
2003 #90
