Crankcase breather pressue
NormSail350
Post by NormSail350 »
Hi all,
It has been a while since I have posted a question, generally because well, I have not had any major issues other than just never ending maintenance that I found that I just enjoy when I cannot be sailing. But I have a question. I took my air filter off to clean it, I still have the original air filter with the wire mesh stuf inside. (I removed and cleaned with diesel fuel). However, I have noticed that I have little or no crakcase pressure from the breather tube that leads back into the air filter. I never really noticed how much pressure there was over the last few years that I have owned the boat, but there was always some little bit of oily residue dripping onto the air filter. Just a little, bit that I believe is absolutely normal, but this seems to have stopped or is very minimal and I really don't feel much pressure out of the tube when the engine is running. I replaced the breather tube (old one was a little gummy and had some black gook in it), I pulled the crankcase cover to inspect (clean as a whistle) including the wire mesh screen inside the little cage in the top of the crankcase cover. I don't see any valves (like a PCV valve on a gasoline car engine) on our M35B's.
Engine seems to be running fine, but no noticeable pressure out of the tube (and the new tube was bone dry after running for a few hours yesterday).
Normal? Do you have perceivable pressure (puffs of crankcase gases) out the tube? Thoughts/comments?
NormSail350
Escape (hull #40)
Palmetto Bay, FL (Miami)
Re: Crankcase breather pressue
Easy to verify that there is no restriction in the tube. Remove it from the air filter and blow into it. Should be zero resistance.
If you have a foam air filter, a good idea to replace it every couple of years. I have seen them designate and the pieces sucked into the engine.
Post by ElizabethG »
Brett is spot on...
That foam will basically rot over time. Mine crumbled in my hand.
Per a recommendation from Ken Krawford a few years ago, I replaced mine with a K & N filter.
Monty
Post by Monty »
do you have a model number or equivalent for the K&N filter you used on the 350?
Steve Montgomery
Salty, hull #418
Deltaville, VA
Hi Steve,
I ordered mine from eBay back in July of 2021.
It was a K&N RU-2450 Universal Clamp-On Air Filter. They are not cheap at about $60
Looks like Amazon has them as well.
