Exhaust Hose length
Exhaust Hose length
Post by nybor »
Hi all. Quick question. Has anyone replaced the hose (2" diam) from the water muffler to the seacock? If so how many feet does it take? I am guessing around 10-12 feet???
thanks
seatime2
Re: Exhaust Hose length
Post by seatime2 »
Hi Dave,
I had mine done last year and the service engineer ordered a 3 metre length which worked out fine.
Cheers, Richard
Nancy Scott #439
Monty
Post by Monty »
I bought 13' of Shields 250 Series ShieldsFlex II with wire from Go2Marine 2 years ago. Had enough to trim the edges and maybe a few inches extra. This also covered from the motor to the muffler. Make sure you put the big turn in the hose before it exhausts out the hull. I laid it out in the sun for a little while to loosen it up. Wasn't the worse exhaust hose replacement I did; at least you can get to it reasonably well. Steve
Steve Montgomery
Salty, hull #418
Deltaville, VA
Post by nybor »
Perfect. THANKS. Yeah, I look at that bend and it scares me...
