Transmission Drain Bolt Crush Washer
Post by ElizabethG »
Like most of you, I have the HBW150A / ZF15MA transmission.
I'm looking for a source for the drain bolt crush washer which I believe is copper. I understand that these are unique and can be hard to find.
The p/n I found on this forum is 3306301016, but no mention of a source.
2004 C350
#193
russp
Re: Transmission Drain Bolt Crush Washer
Post by russp »
Hi,
They seem pretty readily availalble. https://marinepartssource.com/ring-seal ... 3306301016
Good luck with it.
Perfect!
Thanks Russ!!
2004 C350
#193
