Hub size of Michigan prop M series
Greetings, I am about to order a “Prop Protector”. Does anyone have the diameter of the forward end of the Michigan “M” series 14 x 10 3 blade prop? The prop protector needs to be 1/2” larger diameter than the prop hub. Thank you.
