Hull ID number
BillBerner
Contact:
Hull ID number
Post by BillBerner »
Can any body tell me where I can find the complete hull ID number?
Expected to see it stamped into the transom somewhere, but couldn't see it
Bill Berner
C350 #66
Stamford, ct
Bill Berner
#66, Stamford CT.
Re: Hull ID number
Post by AynB »
It's not on the transom ( it's not a little boat! :-) ).
The number will be found to starboard just below the rubrail - well aft.
al
Re: Hull ID number
Post by AynB »
I knew I had a photo of our surveyor getting the HIN...
al
BillBerner
Contact:
Re: Hull ID number
Excellent!
Thankyou.
Bill Berner
Bill Berner
#66, Stamford CT.
SeaBreeze78
Re: Hull ID number
Post by SeaBreeze78 »
Greetings all:
My Hull Identification Number (HIN) is CTYV0078A303.
I believe I have deciphered all but the “V”. The CTY denotes Catalina. The 0078 denotes the hull number. I believe the “A3” denotes August. of the year 2003. “03” Definitely denotes the Model year 2003.
I know the other fleets have a letter denoting there fleet. I believe the C22 is a “N”.
Does the “V” only mean the C350? Does it by chance also define it further that my C350 has a Wing Keel?
Thanks in advance to any who can shed light on this,
Dana
Re: Hull ID number
Dana you are correct. The V designates the boat as a 350 model. I believe all Catalina hull numbers conform to the same coding shown below.
Hull Identification Number Decoding
CTYV0078A303
CTY= First three letters.
This is the Manufacturer Identification Code for Catalina Yachts, Inc. It is on all Catalina boats.
C = Next single letter.
This is a letter that indicates the model type. A “V” in this position indicates a “Catalina 350” model. (Whereas an “H” is a “Catalina 22” model, etc.)
0499 = Next four numbers.
This is the hull serial number. It is a number assigned to a hull, numerically in order as each boat is produced. So the first hull is “0001”, the fiftieth hull is “0050”, etc. Only one boat of that model will have that number – it is unique to the model. This number is the number you can use on your sails. And since it tells you where your boat fits in production order, it tells you a great deal of information about the modifications your boat may have.
A3 = Next letter and number.
This is the manufacturing date. It is the date the hull was produced – the calendar year and month that the boat was built.
I = The Next letter
This indicates the month of manufacture
A = Jan D = Apr G = Jul J = Oct
B = Feb E = May H = Aug K = Nov
C = Mar F = Jun I = Sept L = Dec
7= The next number
Is the last number of the year that the boat was manufactured. So for example, “3” is a boat that was manufactured in 2003. It is either the same year as the model year (below), or the year prior.
03 = The final two numbers.
This is the model year of the boat. So for example, “03” is a 2003 model year boat.
Finding this number etched in the gelcoat on the starboard aft quarter of the boat can sometimes be difficult especially if the hull has been compounded a few times. Laying a piece of tissue or tracing paper laid over the area and then lightly running a pencil will help bring out a faded hull number.
Guinevere
Re: Hull ID number
Post by Guinevere »
A bit off topic but this thread brought up a question that I could never find the answer to...
How many 350s (original design, not Mark II, 355s, etc) did Catalina make?
Guinevere
#243
