Use Sea Flush Snorkel for winterizing engine
Kingofcary
Post by Kingofcary »
Hi All ... has anyone had experience using the sea flush snorkel to winterize via the Shurflo strainer that is in the Catalina 350 ??? Appreciate any input .. tx ... Dennis
elk
Re: Use Sea Flush Snorkel for winterizing engine
Post by elk »
I've used this funnel for the past 7 years to winterize the engine. It makes it more convenient and avoids spills. I set it up, start the engine, add 2 gallons of antifreeze, shut the engine down. Work like a charm. Follow the instructions that come with it.
Ed Kruzel
S/V Emily
Hull #399, 2006 C350
Cataumet, MA
belladonna
Post by belladonna »
I use the Sea Flush Snorkel also and have found it to be easy to use and very convenient. I also use a Shop Vac in the blow mode before the antifreeze to blow water out of the seacock before I shut it, that works great also.
Jim Lassiter
