Recommendations for Replacing Electronics
I'm considering replacing the original Raymarine electronics (C80 Chartplotter, ST6002 autopilot, etc.) with upgraded equipment on my 2008 C350 MKII. Adding AIS integrated into the chartplotter is a "must have" while radar and forward looking sonar are "nice to haves." I'm leaning towards B&G's Zeus2 or Zeus3 systems. Anyone who's done a complete electronics upgrade and has any recommendations, as well as pitfalls to avoid, I would appreciate hearing from. Thanks in advance.
Re: Recommendations for Replacing Electronics
I just replaced all of my Raymarine systems with Garmin. Garmin autopilot, Garmin MFD at the helm, and Garmin wind speed. Everything is now running on a NMEA 2000 network. The Garmin MFD is capable of forward sonar and radar, although I do not have either installed. The only "gotcha" I ran into is the depth sounder. Although it is a Waymar sounder made for Raymarine, it would not connect to the NMEA 2000 network with a NMEA 2000 converter. Tech support lead me to believe that Raymarine uses a custom signal that only Raymarine products will communicate with. So I will need to either replace the the depth sensor or get a Raymarine converter (both around $300 Cdn) For now I rewired the Raymarine display temporarily.
Thanks very much Ralph. I really appreciate the info and will put Garmin on the list possibilities.
I replaced all of ours with new Raymarine (e95, i70, HD color radar, pre-Evolution autopilot) with the exception of the sensors themselves when we bought the boat in 2012. Used an iTC-5 to interface to the existing sensors. All new Seatalkng network (NEMA 2000) and SeatalkHS for radar.
Not a small job but the system works very well and I REALLY appreciated the access and routing that was available in the 350. Much easier to work in than a lot of boats!
Guinevere
#243
Guinevere
#243
Guinevere
#243
#243
Thank you Bob. I very much appreciate the input.
