I'm a fairly new C350 owner (Got it in December 2005) and very much a neophyte in knowing all of the systems on board and climbing through these forums like mad. I have a question on the knotmeter and didn't see any forums that addressed instruments so I'm posting this question here.
Is there a way to calibrate the knotmeter or is it's basically locked?
A couple weeks ago we were in a fairly good breeze and the knotmeter indicated we were doing 4.5 knots. I have had years of sailing experience and my feelings told me that we were going faster than 4.5 knots. I have a Garmin GPSMAP 76CS handheld GPS which I retrived to compare it's indication with the Knotmeter. The GPS indicated we were doing 6.25 Knots (Yes, I had it's units set for Knots and not MPH). This led me to believe the knotmeter may be out of calibration ... if such a thing exists. If this is not possible, what could cause the low reading of the meter? Thanks for any thoughts on the matter.
Knotmeter Calibration ... is this possible???
knotmeter calibration
barnes 01, there usually is a way to calibrate. It depends on the manufacturer. Also, I know it may sound simple, but the GPS was indicating SOG. Was there any noticable current? What were the comparable readings on a reciprocal course?
Sam
LONGHAWK #173
Sam
LONGHAWK #173
Thanks to you both. I was on Lake Lanier which has virtually no current. Delta between the GSP and knotmeter was relatively the same both directions. The instruments are Raymarine and I when I went back to the Owner's Handbook, I did find the section on calibration. Thanks. Hopefully this will allow me to correct the problem.
Raymarine Manuals Online
Here's a link to the Raymarine ST60 Speed manual online:
http://www.raymarine.com/raymarine/Subm ... 0Speed.pdf
On page 26 (page 39 of 53 if you are following along in Acrobat ???) it has the calibration procedures.
Raymarine does a pretty good job of providing its manuals online. They should all be listed here:
http://www.raymarine.com/raymarine/Defa ... &Section=3
Good Luck!
Good Luck!
Tim Brogan
April IV C350 #68
Seattle
April IV C350 #68
Seattle
Let me Know
If you figure it out let me know. I finally gave up (maybe I am a bit slow) and keep in mind its about 1.8 slow. I guess it doesn't matter because eventually it just stopped working at all with regards to speed. It will tell me SOG which it gets from the GPS and I can read with out my glasses, but speed is always 0. The paddle wheels spin freely but that's about it.
I have the directions which don't seem to matter.
